Added "Daylight 4.0" intelligent lighting template,and more
Homestyler Official 2022-3-17
Floor Planner 08/2021 Release Notes - 【Render】 related updates
1.Added "Daylight 4.0" intelligent lighting template
2.Rendered pictures supported "Download Material ID Map"
0 1797 0
