Added scaling tool to customized models,and more
Homestyler Official 17 Mars 2022
Floor Planner 08/2021 Release Notes - 【Interior Modeling】 related updates
1.Added scaling tool to customized models
2.Supported to switch rooms or display all rooms
3.Customized model supported independent editing
4.Supported to apply materials to customized models while modeling
5.Left click to evoke the menu bar
Change the menu bar that appeared by right-clicking to the left-clicking model to display the menu bar.
Maintaining a unified operation mode with other modules can also help us discover and use functions more quickly in the design process.
6.Newly added geometric model
7.Added eraser function
8.Added three-point arc drawing function
9.Supported displaying "Sunken Ground"and "Outside Area"areas
0 2796 0
