Allow 3D fillet and revolve,and more
Floor Planner 09/2021 Release Notes - 【Interior Modeling2.0】 related updates
1.Allow 3D fillet and revolve
“3D Fillet” function
“Revolve” function
2.Custom models in My Favorite supported renaming
0 2334 0
