Draw curves with Interior Modeling 2.0,and more
Homestyler Official 2022-3-17
Floor Planner 12/2021 Release Notes - 【Interior Modeling2.0】 related updates
1.Draw curves with Interior Modeling 2.0
2.3D text can be converted into a model, and can be further edited with the material and modeling
3.Added batch extrusion function
4.Supported modifying the width of the light band
0 1864 0
