Added panorama 4K resolution,and more
Homestyler Official 2022-3-17
Floor Planner 01/2022 Release Notes - 【Render】 related updates
1.Added panorama 4K resolution
2.Supported the conversion of the uploaded location image into a spherical image
3.Supported adding text and pictures in panorama
4.Supported for deleting pictures in the image window of the design interface
5.【Member Exclusive】Supported edited image to save as
6.【Member Exclusive】Edit image to add free crop function
0 2424 0
