Click "Customize-Customize Floor" and select the room to enter the customize floor interface. Select the floor and click "Go to Tile Flooring" to enter the tile flooring or paving interface. You can select different tile patterns in the "Pattern" on the left and drag them on the floor. Click the material icon in the right property panel and you could replace the material for each shape.
Attention: replacing the material in the general design interface will overwrite the previous floor tiling.
