How to set the thickness of different wall models?
Homestyler Official 2021-3-2
Click "Customize-Customize Wall" and select the wall to enter the customize wall interface.  After drawing the shape with the drawing tool, click on the shape and enter the thickness value in the "Extrusion" input box. This allows you to set the thickness of different wall shapes.
0 1681 1
评论(1)
Steve Ziring 2022-7-27
How do you connect extruded walls together when they are outside corners? I extruded my walls 6" but now have 6" square gaps on outside corners. Setting the offset doesn't allow it to hang over.
