How to draw a pitched roof or a gable roof?
Homestyler Official 2021-2-20
Switch to the "RCP" view (means Reflected Ceiling Plan; shortcut key:2) in the bottom left corner to enter the top view. Select the top surface and click "Customize Ceiling" to enter the ceiling interface. (or you can also click "Customize-Customize Ceiling" from the left catalog and select the top surface to enter the ceiling interface). Select gable roof or pitched roof from "Ceiling-Parametric Ceiling-Other" on the left and drag it into the room. The ceiling will be automatically applied to the room, and you can adjust the parameter of rotation angle, slope, the size of the ceiling from the right property panel.
0 8711 9
コメント(9)
Ayden Grace 2022-5-27
But here the roof is below the ceiling. How do I raise it?
34 コメントに返信する
Pru_08_ Harrison 5-13
there should be a whole section named roofs. would make everything whole lot easier
11 コメントに返信する
Anastassia Anastassia 2022-8-7
How to make windows in the roof?
5 コメントに返信する
Meredith W 2022-6-3
https://www.youtube.com/watch?v=4wG717xhzkg@ Ayden Grace
5 コメントに返信する
Kaito Liscombe 2022-9-28
You make your wall height larger under wall settings!@ Ayden Grace
2 コメントに返信する
this is what im wondering@ Ayden Grace
1 コメントに返信する
natalia_horselife 2022-12-28
hi, im still stuck. im trying to do an attick room and im having problems with gable roof - pitched beam, well i tought that doing the ceiling with the modeling method i could be able to add the roof an do an attick room but im really lost with this, maybe you know the correct way, thanks.
1 コメントに返信する
jerlinginteriors 2022-8-21
Did you get itvright? I am also struggling with that, my top ceiling does not want to dissappear
1 コメントに返信する
Cécile L'instant C 8-2
bonjour comment affiche t'on le toit pour la vue exterieure de la maison ? Merci
役に立った コメントに返信する
