Homestyler Official 2021-2-18
Select "Create Room-Structure-door opening" on the left catalog and drag it into the wall to add an opening.
After adding, select the door opening and you can modify the length, width, depth, arch height and elevation height of the door opening in the properties panel on the right. Changing the arch height would turn the rectangular door opening into an arch door opening.
0 2379 1
評論(1)
anide11 9-20
Hi, I created a door opening, then added a door, used the same dimensions as the arch. However, the rectangular door opening is not turning into an arch door opening. Can you please advise? Thank you very much!
