How to modify the height of each floor for multi-floor design?
Homestyler Official 2021-2-18
After adding multiple floors, switch to "Floor 2" below and you can go to the right panel "Layer Setting-Wall Setting-Size-Wall Height" to modify the height of the second layer. Select "Floor 1" below and you can go to "Layer Setting-Wall Setting-Size-Wall Height" in the right panel to modify the height of the first floor.修改多层高度.gif
0 3997 1
评论(1)
rafa_risko 2023-3-6
Please make the minimum wall height lower, to 1 meter
1 回复
