How to change the wall type as load bearing?
Homestyler Official 2021-2-18
Left-click to select the wall in 2D plane view, you can modify the properties of the wall in the right property panel "Wall Height-Basic Parameters-Attributes-Wall Type". You could set it as load bearing or non-weight bearing, and you could set it as generic, concrete or brick.
0 1579 1
評論(1)
Egnoto Private Limited 10-14
kudos
