How to export the floor plan?
Homestyler Official 2021-2-18
Hover the toolbar above "Export" and you can choose and click to export the floor plan with or without furniture in .png format. After clicking, wait for the floor plan to finish exporting  the floor plan and then you can view it from the default download file of your computer.
0 6159 12
评论(12)
Jamie Campbell 2022-2-26
When I am exporting, the floor textures are not updating and showing some grid and default textures. How to solve this?
10 回复
Denis Hogan 2023-1-11
how to export floor plans with ALL the measurements, inside and out?
3 回复
Eizlan Iskandar 9-21
Question, how do i export with 3D model library that i made with myself, when i export it, it doesnt show in floor plan .png, only furniture
2 回复
bobbybabcock1995 2022-7-28
How can I export the floor plan and it be in sketch mode or wire mode, like black and white without textures
1 回复
Andrea Sova 8-28
I have the same problem. Did you already solve this? Thank you!@ Jamie Campbell
fulya ozbey 6-27
Same problem... Did you able to solve?@ Edgar Albani
i have this problem, i don't know. how did you solve the problem?
Denise Ramos 5-18
Go to preferences (wheel on the top right). Click "Design Settings" (left column). For 2D view choose "black and white".@ bobbybabcock1995
Gloria Bosiakali 2023-4-13
How can I export without having the room type and area showing as the following?
pb3 2023-2-14
The export function is not working. I'm getting the message that you're working on it, but it's not downloading.
Edgar Albani 2022-8-5
i have this problem, i don't know. how did you solve the problem?@ Jamie Campbell
Here the attachment@ bobbybabcock1995
How can I export the floor plan and it be in sketch mode or wire mode, like black and white without textures, I have attached an example
