How to divide an area?
Homestyler Official 2021-2-18
Select the room in the 2D plan view, click "Area-Divide" and left click to draw the room division. After the division is finished, you can select the area and choose the room type or name it yourself. Select a divided area and click "Area - Divide Delete" then you will be able to delete the division.区域划分.gif
0 5209 2
评论(2)
Destini Harris 6-19
How do you remove the lines that appear once a space is divided? Thanks
Steve D'Amico 2022-8-9
I have divided rooms a number of times only to have the divisions disappear later. Is there a way to make the changes permanent?
