Good evening, I have a problem with the '' Floor Opening '' command in the '' Create Room '' panel, it hasn't pierced the floor for a few days, but only the perimeter of the rectangle on the floor itself remains visible. I need to use it because I have to make top view views of a first floor that the staircase reaches from the floor below, I could use the '' edit floor 'command but the rectangular hole is much faster. Thanks to those who will be able to answer me.Emanuela
Hi which level are you opening? If it is the upper floor, you may add vertex if your flooring doesn't work. Edit floor and then add vertex to create the opening. If you are referring to ground level opening as I experienced as well myself that sometimes it doesn't open so I use both floor opening and sunken ground option. If you have a custom build/floor covering on the area you want to open, remember to create the opening hole first in the custom modelling. Hope this helps.
