How to adjust the sunlight parameters?
Homestyler Official 2021-1-26
Click "Render" from the top toolbar to enter the rendering interface. Click "Lighting-Add light" and select a lighting template as a basis, and then you can enter the Customize Light interface.  Click "Sunlight" tab, you can modify the color temperature, intensity and softness of the sunlight (the larger the value, the softer the sunlight). After clicking "Position-Customize", you can manually modify the height and angle of the sunlight.
0 1649 1
コメント(1)
ruim orado 2022-3-8
Hi, using 3% of brightness for the sunlight at 25º angle, the render is overexposed. what is wrong?
役に立った コメントに返信する
