How to make an opening in the floor?
Homestyler Official 2021-1-26
Select "Create Room-Structure-Floor Opening" in the left list and drag it into the scene to make a hole in the floor. After the hole has been opened, you can adjust the size and position of the opening in the 2D plane view by dragging directly, or adjusting the size value in the right property panel.楼板开洞.gif
0 5190 16
评论(16)
Juyeon Cisauk 7-26
yeaah me too, no floor opening.@ lisabecka
There is no floor opening option in my Homestyler. Next to Cylinder there's just Sunken Ground and so on.
7 回复
Tania Bertholdi 2023-1-27
My room is odd shaped - not square, so cannot open a hole using the Floor opening tool. Please help.
5 回复
Vidir Geirsson 7-29
So you need to go to edit floor and then you click the option rectangular floor opening@ lisabecka
3 回复
Mariya Klimchenkova 7-27
How to make an opening in the floor in V 5.0?
3 回复
John Dada 8-23
Found it in V5 under Model Library / Structure / Wall opening / Ground Opening@ Juyeon Cisauk
why dont i have floor opening in the version?
1 回复
helenagomesaraujo98 9-9
Não me aparece essa opção de "FLOOR OPENING"
John Dada 8-23
Found it in V5 under Model Library / Structure / Wall opening / Ground Opening@ lisabecka
John Dada 8-23
Found it in V5 under Model Library / Structure / Wall opening / Ground Opening@ Mariya Klimchenkova
John Dada 8-23
John Dada 8-22
can't open the design you started in V5 into the V4...@ Gina Manolea
go back in V4
Gina Manolea 7-27
go back in V4@ Juyeon Cisauk
Gina Manolea 7-27
go back to V4@ Tania Bertholdi
Gina Manolea 7-27
you need to work in V4 for this option@ Juyeon Cisauk
Juyeon Cisauk 7-26
lisabecka 7-19
Rey Mclane 2023-5-5
Is there a way to lock the openings? Mine keep moving to the 1st floor every time I reopen it.
