How to make an opening in the floor?
Select "Create Room-Structure-Floor Opening" in the left list and drag it into the scene to make a hole in the floor. After the hole has been opened, you can adjust the size and position of the opening in the 2D plane view by dragging directly, or adjusting the size value in the right property panel.楼板开洞.gif
0 5194 16
Commenti(16)
Juyeon Cisauk 26 Luglio
yeaah me too, no floor opening.@ lisabecka
There is no floor opening option in my Homestyler. Next to Cylinder there's just Sunken Ground and so on.
7 rispondere
Tania Bertholdi 27 Gennaio 2023
My room is odd shaped - not square, so cannot open a hole using the Floor opening tool. Please help.
5 rispondere
Vidir Geirsson 29 Luglio
So you need to go to edit floor and then you click the option rectangular floor opening@ lisabecka
3 rispondere
Mariya Klimchenkova 27 Luglio
How to make an opening in the floor in V 5.0?
3 rispondere
John Dada 23 Agosto
Found it in V5 under Model Library / Structure / Wall opening / Ground Opening@ Juyeon Cisauk
why dont i have floor opening in the version?
1 rispondere
helenagomesaraujo98 9 Settembre
Não me aparece essa opção de "FLOOR OPENING"
John Dada 23 Agosto
Found it in V5 under Model Library / Structure / Wall opening / Ground Opening@ lisabecka
John Dada 23 Agosto
Found it in V5 under Model Library / Structure / Wall opening / Ground Opening@ Mariya Klimchenkova
John Dada 23 Agosto
John Dada 22 Agosto
can't open the design you started in V5 into the V4...@ Gina Manolea
go back in V4
Gina Manolea 27 Luglio
go back in V4@ Juyeon Cisauk
go back to V4@ Tania Bertholdi
you need to work in V4 for this option@ Juyeon Cisauk
lisabecka 19 Luglio
Rey Mclane 5 Maggio 2023
Is there a way to lock the openings? Mine keep moving to the 1st floor every time I reopen it.
