How to make an opening in the floor?
Select "Create Room-Structure-Floor Opening" in the left list and drag it into the scene to make a hole in the floor. After the hole has been opened, you can adjust the size and position of the opening in the 2D plane view by dragging directly, or adjusting the size value in the right property panel.楼板开洞.gif
0 5192 16
Commentaires(16)
Juyeon Cisauk 26 Juillet
yeaah me too, no floor opening.@ lisabecka
There is no floor opening option in my Homestyler. Next to Cylinder there's just Sunken Ground and so on.
7 Répondre
Tania Bertholdi 27 Janvier 2023
My room is odd shaped - not square, so cannot open a hole using the Floor opening tool. Please help.
5 Répondre
Vidir Geirsson 29 Juillet
So you need to go to edit floor and then you click the option rectangular floor opening@ lisabecka
3 Répondre
Mariya Klimchenkova 27 Juillet
How to make an opening in the floor in V 5.0?
3 Répondre
John Dada 23 Août
Found it in V5 under Model Library / Structure / Wall opening / Ground Opening@ Juyeon Cisauk
why dont i have floor opening in the version?
1 Répondre
helenagomesaraujo98 9 Septembre
Não me aparece essa opção de "FLOOR OPENING"
John Dada 23 Août
Found it in V5 under Model Library / Structure / Wall opening / Ground Opening@ lisabecka
John Dada 23 Août
Found it in V5 under Model Library / Structure / Wall opening / Ground Opening@ Mariya Klimchenkova
John Dada 23 Août
John Dada 22 Août
can't open the design you started in V5 into the V4...@ Gina Manolea
go back in V4
Gina Manolea 27 Juillet
go back in V4@ Juyeon Cisauk
go back to V4@ Tania Bertholdi
you need to work in V4 for this option@ Juyeon Cisauk
lisabecka 19 Juillet
Rey Mclane 5 Mai 2023
Is there a way to lock the openings? Mine keep moving to the 1st floor every time I reopen it.
