How to import DWG file to generate the floor plan?
Homestyler Official 2021-1-26
In the left catalog click "Create Room" and then click "Import", select "Upload DWG" to import DWG files. Click "Start Importing", select the file, and then the floor plan will be generated. Please read the import tips carefully to avoid failure.导入CAD.gif
0 3925 6
評論(6)
williamlai66 2022-2-12
Why can i import the CAD due to the smaller dimension less than 400mm, but I drawn in CAD as 1:1 scale
5 回複
ahthelife 2022-11-29
When I import a jpg or a dwg it is very small. How do I scale the background image imported to the right size or import it at the correct scale to begin with?
brianlawing6 2022-10-31
NOT ABLE TO UPLOAD FILE FROM AUTOCADTRIED SEVERAL TIMES https://bimmernaviupdates.com/
DARIA MAŁACHOWSKA 2022-10-4
Jak to odczytac na tym programie? pomocy
preetijoshi593 2022-9-13
maram mohamed 2022-8-3
how to restore my design after i pressed on templates option at the same file after i finish the design?
