How to import DWG file to generate the floor plan?
In the left catalog click "Create Room" and then click "Import", select "Upload DWG" to import DWG files. Click "Start Importing", select the file, and then the floor plan will be generated. Please read the import tips carefully to avoid failure.导入CAD.gif
0 3930 6
Commenti(6)
williamlai66 12 Febbraio 2022
Why can i import the CAD due to the smaller dimension less than 400mm, but I drawn in CAD as 1:1 scale
5 rispondere
ahthelife 29 Novembre 2022
When I import a jpg or a dwg it is very small. How do I scale the background image imported to the right size or import it at the correct scale to begin with?
brianlawing6 31 Ottobre 2022
NOT ABLE TO UPLOAD FILE FROM AUTOCADTRIED SEVERAL TIMES https://bimmernaviupdates.com/
DARIA MAŁACHOWSKA 4 Ottobre 2022
Jak to odczytac na tym programie? pomocy
preetijoshi593 13 Settembre 2022
maram mohamed 3 Agosto 2022
how to restore my design after i pressed on templates option at the same file after i finish the design?
