How to adjust the parameters of the cabinet and door?
Homestyler Official 2021-1-26
For each custom model, select the model and you can adjust the parameters on the right. You could also double-click to enter a model and select each panel and board. Similarly, when selecting a part, you could adjust its parameter on the right property panel as well.
0 2159 7
評論(7)
Design Project 2022-4-12
How can I remove handles from cabinets? Can you solve this problem?
1 回複
Lilia Mihalcova 2023-2-15
Добрый день, я не могу добавить на сцену поместить объекты из раздела Custom Furniture, в чем проблема, подскажите пожалуйста.
Design Project 2022-4-19
Unfortunately, the program does not allow you to completely remove the handles on the doors. Do you have an opportunity to fix this in furniture modeling?
Teke Tin Tekes 2022-3-1
Is anyone else having problems changing the material on the cabinets? No matter what I do, the material will not change.
hodo kaise 2022-2-22
can i edit models ?
Homestyler Official 2022-2-11
You could find them in the catalog under "kitchen", check ou the screenshot below:@ carrie.yoshida
How do I access library of appliances (refrigerator, stove, dish washer, wine refrigerator)?
carrie.yoshida 2022-2-10
