How to switch off the size restriction on custom furniture?
When you are in the "Custom Furniture" environment, click "Size Restriction" below and select "Turn Off", and then click "Got it" to cancel the size restriction of the model. But please be aware that  when you turn off the restriction, you can freely adjust the size of the model, and will also need to bear the risk of the result of the adjustment model. It is very likely that there is a risk of load-bearing installation or failure to produce. At the same time, due to modeling restrictions, some models may display errors after the size adjustment exceeds the limit.如何关闭尺寸限制.gif
0 2274 1
Commentaires(1)
disenomarianovo 4 Mai 2022
Pues yo sigo los pasos y no me deja
