Dear Homestylers, it's been a while since our last update. The new Homestyler V4.0 was just launched on 31st August, 2021. Here is the introduction to all the optimizations and new features:
1.【General Features】
1.1【Interface】Upgraded the brand new User Interface
1.2【Interface】New entry for Preferences & Measurement Unit setting
1.3【Interface】Updated the "Beginner's Guide"
1.4【Interface】Added side menu bar to enable faster model searching
1.5【Interface】Added transparent wireframe mode setting
1.6【Interface】Supported function panel customization
1.7【Interface】Optimized category structure in the replacement panel
1.8【Function】Updated Interactive Fabric to simulate fabric effect
1.9【Function】Added elevation view in the design interface
1.10【Function】Wall opening and niche increased arch height adjustment
1.11【Function】Models added related category recommendation
1.12【Function】The model information added Model ID
1.13【Function】Models supported alignment in 9 ways
1.14【Function】Model supported horizontal or vertical distribution
1.15【Function】Model supported scaling by dragging
1.16【Function】Model supported exact and fast copy with shortcut
1.17【Function】Supported customized and separate display of hidden items
1.18【Function】Supported applying current materials to the same models
1.19【Function】Window sill width supported width setting
1.20【Function】Models in "My Fav" can be deleted or moved in batches
1.21【Function】Models in "My Fav" supported to be searched
1.22【Function】The 3D view supported to use the"space bar" to rotate the view angle
2.【Interior Modeling 2.0】
2.1【Interior Modeling 2.0】Supported to switch rooms or display all rooms
2.2【Interior Modeling 2.0】Customized model supported independent editing
2.4【Interior Modeling 2.0】Added scaling tool to customized models
2.5【Interior Modeling 2.0】Left click to evoke the menu bar
2.6【Interior Modeling 2.0】Newly added geometric model
2.7【Interior Modeling 2.0】Added eraser function
2.8【Interior Modeling 2.0】Added three-point arc drawing function
2.3【Interior Modeling 2.0】Supported to apply materials to customized models while modeling
2.9【Interior Modeling 2.0】Supported displaying "Sunken Ground" and "Outside Area" areas
3.【Tile Flooring】
3.1【Tile Flooring】The angle of the floor tiles supports quick rotation by pressing the "space bar" to rotate 45 degrees clockwise each time.
4.【Image & Video Rendering】
4.1【Render】Rendered pictures supported "Download Material ID Map"
4.2【Render】Added "Daylight 4.0" intelligent lighting template
4.3【Video】Video resolution added 540p and you can spend Homestyler points for it
4.4【Video】Support directly drawing curved path and straight path
4.5【Video】Video rendering added advanced mode
4.6【Video】The lamps support brightness change animation in video
Detailed Introduction:
The era of homestyle4.0 has begun! The concise visual interface, flexible and faster operating experience, and brand-new efficient functions - all these will improve your design efficiency. Detailed tutorial:https://www.homestyler.com/forum/view/1486267589863034881
Take curtains as an example: Detailed operation:Open the "Interactive Fabrics", place the "Curtain" model near the window, and click the "Wind Blow" button to set the wind force. Eventually, curtains blown up by the wind are automatically generated.
Change the menu bar that appeared by right-clicking to the left-clicking model to display the menu bar. Maintaining a unified operation mode with other modules can also help us discover and use functions more quickly in the design process.
2.9【Interior Modeling 2.0】Supported displaying "Sunken Ground" and "Outside Area"areas
3.【Tile Flooring】
The angle of the tile floor supports the "space bar" to quickly rotate(the view will be rotated by 45 degrees each time) to help you quickly locate the right angle.
