V4.0.3-Added curve modeling, precise rotation models, and more
Homestyler Official 19 Mai
Updated Functions:
1.【General Features】
1.1【Function】Model supported precise adjustment of the rotation angle.
1.2【Function】Supported applying the current material to the same doors / windows.
1.3【Function】Supported applying the elevation height to the same doors / windows.
1.4【Function】Supported continuous duplication of door and window models.
1.5【Function】The Measure tool supported display multiple measurement size.
1.6【Function】Added update log link in the design interface.
2.【Interior Modeling 2.0】
2.1【Interior Modeling 2.0】3D text can be converted into a model, and can be further edited with the material and modeling.
2.2【Interior Modeling 2.0】Added curve drawing in Interior Modeling.
2.3【Interior Modeling 2.0】Added batch extrusion function.
2.4【Interior Modeling 2.0】Supported modifying the width of the light band.
3.【Rendering&Video】
3.1【Video】Added time frame management in the advanced mode of video rendering.
3.2【Render】Supported changing room names in 720°Virtual Tour.
3.3【Render】Allowed remark on renders.
3.4【Render-Member Exclusive】Optimized watermark removal process.
3.5【Render-Member Exclusive】Supported for upgrading resolution after Lightmix.
3.6【Render-Member Exclusive】Added color temperature adjustment in Lightmix.
3.7【Render-Member Exclusive】Supported saving the Lightmix parameters as lighting template for further rendeirng.
Detailed Introduction:
1.2【Function】Supported applying the current material to the same doors/windows.
1.3【Function】Supported applying the elevation height to the same doors/windows.
After placing the window/door, first adjust the elevation height of a certain window from the ground. The system will prompt you whether you want to apply the height to other windows with one click, if yes, just click "Apply".
3.【Rendering&Video】
When you render videos, enter the advanced mode to create clips by adding keyframes. When you finish the clip, turn on the "Time Frame" switch.
If your clip is set as "grow effect", then you can precisely control the starting and ending time of the animated motion of each model. You can also adjusting the duration between keyframes by dragging the little dot on the main timeline(each dot represents a keyframe you took).
If your clip does not have grow effect, you can still adjusting the keyframe timeline by dragging the keyframe dot.
Open the image album, select 720°Virtual Tour and click "Edit", then you can modify in "info-Room Name".
In the case that you have created too many renders in one design, you can now mark important ones with flag, and you can batch download, delete, and do more operations on the marked renders together.
Optimized the removal of watermark function, open the image album, select all the rendered images you want to remove the watermark, and click "Remove Watermark" above.
Now the renders that have been adjusted with Lightmix can be upgraded in resolution.
After entering Lightmix, you can adjust the color temperature properties of each type of light sources on the right.
After adjusting the lighting parameters in Lightmix, click "Save As Lighting Template" below to synchronize this lightmix parameters to the lighting template of the rendering interface for further rendering, which would allow you to use the lightmix lighting setup to render other scenes.
0 3305 2
Commentaires(2)
Светлана К 22 Mars
ок
brimberrychristie 30 Mai
wonderful
