How do I modify a room dimension?
Homestyler Official 2022-8-26
You can modify the room size by dragging on selected wall segment directly in 2D/plane view. For precise adjustment, you can enter your specific dimension in order to achieve your desired requirements.
If you can't change the width and length of the wall, try the following:
we need to display the dimensions of the wall as follows: View --> Display Settings --> Dimensions --> Wall Centerline/Wall Inner Face. (Methods as below)
0 6844 3
コメント(3)
peacefulguy forhonor 2022-6-7
What to do if I only can change sizes with moving mouse, I don't have specific dimension near the walls
4 コメントに返信する
how to change sizes?
1 コメントに返信する
SATISH THORAT 2022-9-17
same issue. cant see room dimensions.@ peacefulguy forhonor
役に立った コメントに返信する
