Can you import underlying images/CAD?
Homestyler Official 2021-1-26
You can import an underlying image to draw your floor plan from the left menu by selecting the “Create Room - Import Floor Plan” option, where you can choose a .jpeg/.png image or.dwg CAD file to import as a background image that will display underneath your design. You can also hide/delete or adjust the transparency of this background image from the bottom.
0 9574 4
評論(4)
purvi 2022-10-5
I tried to import my Autocad dwg file but it says the floor plan is too small - either X or Y direction is smaller than 400mm. The drawings is drafted in mm and it is definitely more than 400mm. how can i resolve this issue?
12 回複
hmr.ferreira 2022-12-22
How do you solved this problem?@ purvi
6 回複
naomi007 2022-1-29
My imported floorplan image seems to be locked and stopped moving together with my new drawing overlay. Now the scale is off and I am unable to move the imported image and new drawing togther. What could be the problem? It was working fine before but I cannot see that any setting has been changed to cause this.
5 回複
Giada 2023-4-6
È possibile caricare un jpeg da utilizzare come sfondo di una parete?
