Hi, I would like to limit the teal tile walls only to the shower space and leave the remainder of the walls bare, but I am not sure how to do this. Can someone assist? TIA.
When you tap on the walls,there is a bar that shows up. In that bar it says "tile flooring". Click on it, and it will show you just that wall. From there, use the rectangle symbol at the top to draw the section of the wall you want green. You will then be able to color the two sectiobs differently. (but only in tile flooring.)
