Lowering the outside area
Denys Koch 2021-6-22
Hi,
is it possible to lower or adjust the level over the outside area? somethink like below 0m or below basement 1 level?
Thanks
0 958 2
评论(2)
Alex N 2022-1-28
it was little hard to achive. but basement level with basement custom flooring alsomst worked. The ceilling of the ground floor should be edidted to let custom floor from the basement to popup.
Homestyler Official 2021-6-23
Hi, you could make a higher floor as the 1st floor, and take the lower levels as if it is below the ground level.
