Lowering the outside area
Denys Koch 22 Giugno 2021
Hi,
is it possible to lower or adjust the level over the outside area? somethink like below 0m or below basement 1 level?
Thanks
0 957 2
Commenti(2)
Alex N 28 Gennaio 2022
it was little hard to achive. but basement level with basement custom flooring alsomst worked. The ceilling of the ground floor should be edidted to let custom floor from the basement to popup.
Homestyler Official 23 Giugno 2021
Hi, you could make a higher floor as the 1st floor, and take the lower levels as if it is below the ground level.
