Trying to get outside area to work correctly
Dave Terry 2021-6-18
When i try to make a grass area, i can not seem to ever get the grass area (outside area) to but up against the house.
So is there a way to resize it to do this. I do not see the option to do this, or am i just doing something completing wrong.
Every once in a while, i get it to go agaist the house, but most all the time, i try to make a line across the edge of the house and it just does not work. Thank you to whoever can find me a answer to this...
0 2665 7
評論(7)
a baile 2022-3-31
How can I resize an outside area once it is created? Doesn't seem to be a way to do this.
3 回複
Kaczor Donald 8-17
homestyler tutorials recommend making a room with low walls and no ceilig . This outside area option is something that does not work well
Sophia Olson 5-23
How do you even add grass?
Dave Terry 2021-6-21
It worked much better. Thanks, Before i kept trying to make a square, instead of putting the line against the house.@ Merel
Dit it work?
Merel 2021-6-21
Dit it work?@ Dave Terry
I will try that and get back with you, If it was that easy, this will be embarrassing for me
Dave Terry 2021-6-19
I will try that and get back with you, If it was that easy, this will be embarrassing for me@ Merel
Already tried this?
Merel 2021-6-19
Already tried this?
