This is a request to have the ability to put project renders and rooms in the order we want to display them. For example: I am trying to order my renders from 1 floor to 3 (each floor is a very large room) floor but I can't seem to get it to work that way. This order is important because I need the renders to show up in that particular sequuence. Other people have had this problem where they can't get the right rooms to appear in the right order. If there is an easy way to do this already please tell me, otherwise, please add this feature.
Hi Grace, when editing project, the "Space Showcase" section will be separated into different parts depending on the number of rooms you have in your design and it will show up as "unnamed space" if you did not name each room in the design. When you "add photo" in each room, you could choose renders taken in that corresponding room (which is the camera position when you take the render. We are aware of the photo order issue when you save the project and this problem will be fixed soon.
