How do you create a pool in Homestyler? I've tried many different ways and still can't figure it out.
Create a basement, change the basement floor height to however deep you want your pool. Then edit your 1st floor (floor edit) to created the opening. Just note that your 1st floor plan should be very close to being complete. Every time you move an outside wall on the first floor-your hole for the pool will close and you will have to do it all over again. This is the way I do it, but you can wait and see what HS does in the tutorial.
