Just like other flavors, mango-flavored vapes can slightly stain your teeth over time. However, when compared with cigarettes, the staining is much less. The main reason why vapes can stain your teeth is because of the ingredients that are present in the vape juice. Most vape juices contain nicotine. Though nicotine looks colorless in its pure form, when it reacts with oxygen, it turns yellow or brown.
Even without nicotine, the sweet flavorings and chemicals that are present inside the vape juice can form a thin layer on your teeth, which makes your teeth look less white. Also, the heat from the vape can dry out the saliva in the mouth, which plays a vital role in cleaning your teeth naturally.
Even though vapes like the mango pineapple vape taste delicious but they do stain your teeth. You can prevent these stains by brushing your teeth regularly and drinking plenty of water throughout the day to keep your mouth hydrated.
