Hello!
I started experiencing an issue with importing floor plan images while working with multiple floors.
I know importing separate images for each level was never an option (it's possible with dwg files but not regular images) but I found my way around - I used to combine them all into one by changing the transparency and color of each image and layering them in a photo editing software, then I uploaded it to my project and it showed on each level as a base image. It was a bit confusing to work with plans that mixed all the floors into one but at least I could do it back then.
Now, ever since the latest update, this method no longer works. I can only see the base image on the first floor and the "Base Image Setting" is gone everywhere else. I thought that maybe now we can finally upload different floor plans for each level but sadly it's not the case - uploading a new one empties the view on each floor anyway.
Before, as seen in my older project:
After, in my most recent one:
This was a very essential feature for me because I often have to work with plans that aren't in the dwg format and the new update made it pretty much impossible so I was wondering if someone has a new workaround for this?
