Challenge Overview:
To make our community more interesting and offer users different room styles, we are launching a challenge for the design of empty room templates on our app. You can create your own favorite room that meets the challenge requirements, and if your room template is selected, we will label the creator's avatar & nickname within the room design and publish it on the app community for everyone to use. In addition, we will also provide membership and 4K renders as rewards for selected entries. Homestyler welcomes everyone to unleash their creativity and participate actively. Click here to submit designs.
Challenge Time:
2023.04.18-2023.06.18
Challenge Awards:
There will be no final selection after the end of this challenge, and evaluation will be carried out every Monday. Selected room template designs will be displayed for one week at the top of the challenge page on the web and in Homestyler app for other users to use.
At the same time, we will notify you through Inbox and award the creator with 10 points, 10 x 4k renders, and one month of Styler!
TherThe homestyler app will update a new room every Tuesday, if you are selected, please don't worry, we will publish the works to the homestyler app according to the order of submission timee is no limit to the number of entries or winners for this challenge. Everyone can submit multiple works, and rewards can be obtained every week. Let's participate in this challenge together!
How to participate:
Go to https://3d.homestyler.com/?preciseFP=true to create an empty room template that meets the challenge requirements, and submit your room designs to this Challenge.
Challenge Requirements:
1.Room Creation
1)The number of spaces shall not exceed 3, and the partition walls shall not block the sight of each space
2) You need to set a project name for the project (this name shall be consistent with the empty room name)
3) There are no restrictions on room size, wall height, room style, and room type
2.Room Assets
1) 3D furniture models, floor lamps, ceiling lights, etc. cannot be placed in the room (plant models can be placed outside the room to increase the atmosphere of the room, and spotlights can be placed indoors to increase brightness)
2) Materials can be added to the walls, floors, ceilings and models created by Interior Modeling to reflect the style and characteristics of the room
3) Structural models (doors, windows, door openings, wall niches, etc.) can be added to the room
4) The room can be created using the functions of Customize Ceilling, Customize Wall, Customize Floor and Interior Modeling, but Tile Flooring cannot be used.
● It is necessary to group internal models of the same type. For example: Stairs and railings are two types, so you need to combine stairs and railings separately, not together. The user cannot change the handrail material individually.
3.Room Rendering
1) In the rendering interface, the final camera view of the rendered image needs to be saved
Method: Enter the rendering interface > adjust the appropriate viewing angle > click "Save Current View" at the bottom right
*Cannot render with camera clipping
2) A rendering with a ratio (2:1) and resolution (2k and above) needs to be submitted as the cover image, which will be displayed on Homestyler app later.
3) The camera angle of view of the rendering image shall be selected from the horizontal angle of view, please note that the upward/downward angle of view cannot be selected
4) The light in the room should not be overexposed/too dark, please ensure that the brightness of the light source in the room is normal
Creation Showcase:
In the process of creation, it can be made from outdoor, indoor, courtyard and other spaces. The following images are sourced from Pinterest:
At the same time, you can also check the room templates in Homestyler app to understand the creation direction:
FAQ:
1. Where will the selected room template designs be displayed?
Firstly, please download Homestyler App. On our App's "Design" page, click "Start with Room Template to Design" and you can see the selected design. Click on the cover to view the design name and creator avatar & nickname. You can also click on the creator's avatar to enter his/her personal homepage.
2. How can I check if my design is selected and used in Homestyler app
After the design is selected, we will pin the selected design at the top of the challenge page on the web for a week (update the pinned design at the top every Monday), and once the design is added to our app, we will notify you and send you awards via Inbox.(
3.If my Homestyler account is canceled, will the selected designs still be displayed in Homestyler App?
Yes, please kindly note that after the account is canceled, we will not be able to see your personal information, and the creator's avatar & nickname after opening the room template will indicate Homestyler official account. As shown below:
4.My room is selected, but why isn't it showing in the homestyler app?
The homestyler app will update a new room every Tuesday, if you are selected, please don't worry, we will publish the works to the homestyler app in the order of submission time.
