Trying to get outside area to work correctly
Dave Terry 18 Giugno 2021
When i try to make a grass area, i can not seem to ever get the grass area (outside area) to but up against the house.
So is there a way to resize it to do this. I do not see the option to do this, or am i just doing something completing wrong.
Every once in a while, i get it to go agaist the house, but most all the time, i try to make a line across the edge of the house and it just does not work. Thank you to whoever can find me a answer to this...
0 2664 7
Commenti(7)
a baile 31 Marzo 2022
How can I resize an outside area once it is created? Doesn't seem to be a way to do this.
3 rispondere
Kaczor Donald 17 Agosto
homestyler tutorials recommend making a room with low walls and no ceilig . This outside area option is something that does not work well
Sophia Olson 23 Maggio
How do you even add grass?
Dave Terry 21 Giugno 2021
It worked much better. Thanks, Before i kept trying to make a square, instead of putting the line against the house.@ Merel
Dit it work?
Merel 21 Giugno 2021
Dit it work?@ Dave Terry
I will try that and get back with you, If it was that easy, this will be embarrassing for me
Dave Terry 19 Giugno 2021
I will try that and get back with you, If it was that easy, this will be embarrassing for me@ Merel
Already tried this?
Merel 19 Giugno 2021
Already tried this?
