0 32 2
kamil podsiadło7 April
Non-rebated/ rebated doors
Hi,
Is there a way to place the doors that are aligned with wall like on this pictures?
Currently I make them using customized modeling but it's a little annoying to do so..
Comments(2)
.jpg/.jpeg/.png/.gif/.bmpUPLOAD
    kamil podsiadło10 April
    Thanks for the tips. I use the second method usually. I don't think changing wall thickness is an option when I draw real life room project.@ Homestyler Official
    Hi Kamil, there are two ways to achieve it. 1. you could select a flat-shaped door in the catalog, drag it into the design, uncheck the door pocket (in the right property bar), and adjust the wall thickness. 2. You could drag in a squared wall opening, adjust the shape, then go into customized modeling to draw the door slab.
    Homestyler Official8 April
