The Homestyler Team version now allows you to create and manage your own title block templates and reuse them on sheets.
Step 1: Open Title Block Settings
- Go to "Team > Sheet Settings" in the left panel.
- Click "Title Block Settings".
- Click "Create New Title Block".
Step 2: Create a New Title Block Template
In the Title Block Template Settings dialog:
- Template Name – Enter a name for this title block.
- Sheet Type – Choose the type of sheet this template will be used for (Floor Plan, Index Sheet, or Elevation Sheet).
- Print Sheet Size – Select the print size (e.g., A3).
- Title Block File – Click Upload File and upload your title block drawing in .dwg format.
- Choose the "Language" of the template. *If a language is configured, the title block will be displayed when the design tool is set to that language.
- Click "Confirm" to open the title block editor.
(**Sample tile block template:Copy and paste the link below into your browser to download the file:
https://ezhome-uat-cad-assets.oss-cn-beijing.aliyuncs.com/legend/b98ecc3d-c917-4043-924b-7530ead9a638_legend.dwg)
Step 3: Define the Sheet Layout Area
After the DWG is loaded:
- A blue frame labeled Sheet Layout Area appears on top of your drawing.
- Drag the edges or corners of the blue frame to resize and move it.
- Make sure the blue frame aligns with the actual drawing area of your uploaded title block (the printable area where the plan/elevation will be placed).
- Click "Save" when finished.
Step 4: Bind Fields to the Title Block
On the left side of the editor you will see Fields, grouped as:
- Project Info (e.g., Project Name)
- Sheet Info (e.g., Drawing Title, Scale, Paper Size, Date, Drawing No.)
To bind data to the title block:
- Select a field in the list (for example Drawing Title).
- Drag and drop it onto the corresponding cell / position in your title block template on the right.
- Repeat for all fields you need: Project Name, Scale, Paper Size, Date, Drawing No., etc.
- Use "Save" to store your changes.
When the sheet is created, these fields will automatically read the related project and sheet information.
Step 5: Adjust Text Style in the Title Block
You can fine‑tune the appearance of each text field:
- Click the text on the title block to select it.  The text is left-aligned within the text box.
- On the right, under Text Settings, edit:
    Text Height – enter a value to change the text size.
    Rotation Angle – enter the angle in degrees to rotate the text (for example 90° for vertical text).
- The selected text will update immediately.
Step 6: Manage Title Block Templates
Back in Title Block Settings, you can:
- Set as Default: Apply a template as the default title block for that sheet type.
- Setting: Set up the title block template information, like name, type, language.
- Frame Edit: Re‑open the template editor to adjust layout, field positions, or text settings.
- Sync: Sync the current title block template to other types of drawings
- Delete: Remove templates that are no longer needed.
Once configured, your custom title block will be available to all team members for the selected sheet type, ensuring consistent and automated project documentation.
