What is AI Render?
AI Render uses the camera view combined with tags and prompt input to intelligently generate stunning visualizations within one minute.No professional rendering skills or complex parameter adjustments are needed, eliminating the hassle of complicated rendering entirely!
You can freely choose lighting atmospheres, add people, pets, decorations, and more to quickly enrich your scene and significantly improve rendering efficiency.
Entrance
Find “AI Render” in the top menu under 「AI Tools」 and click to enter the tool.
How to Use?  Create your perfect render in 4 simple steps
Step 1: Add rendering atmosphere prompt
Select lighting, people, pets, or other elements as needed. Selected tags are automatically added to the input box and can be removed or replaced by clicking again. For custom requests, type directly into the input box.
Step 2: Select image proprotion and resolution
Step 3: Set camera angle
Use the shortcut keys (W: forward, S: backward, A: left, D: right, Q: up, E: down) plus mouse movement to set your rendering angle.
If the camera is blocked by walls, enable the "Clipping" function and adjust Clipping Depth to avoid walls. Do not clip furniture or the floor.
Recommended Camera Settings
FOV
   * Full room view: 55° recommended
   * Close-up: 20°–30°
Height:  Normally set to 1000–1200 mm. Adjust accordingly for double-height villas.
💡 Tip: Click“ Save Current View ”to store your camera angle for later use.
Step 4: Click “Generate “to start AI rendering
    * Credit Consumption:  Each AI image generation (2K) costs 30 AI credits.
    * Generation Time:  Approximately 1 minute.
    * View Renders:Click the Gallery button in the top-right corner to view your generated renders.
Video Tutorial:https://www.homestyler.com/learn-help/view/203
